QNAP [ Ubiquiti UniFi ] Wi-Fi Management
Wow, that was Fast ! Merci beaucoup Monsieur Qoolbox !! :-D
Upgrade from 5.6.30 to 5.7.20 went perfectly, no issues and running fine.
jaytee a dit:
Hi Stéphane, Unifi Controller 5.7.20 Stable is now available.
https://community.ubnt.com/t5/UniFi-Updates-Blog/UniFi-5-7-20-Stable-has-been-released/ba-p/2271529
When you get a moment, can you do the magic that you do ? :-D
FYI afaik older versions of UniFi WAPs are not supported by 5.7.x
I dont care i'm already on 5.8.3 :)
Stephane 5.6.36 was released as LTS Stable, which might be a good version to release.
Hi Simon,
i cant downgrade revision regarding QnapClub which is hosting Unifi...
if i do it will not process on Repo
I need a 5.7.20+ in version..
UniFi 5.7.23 Stable has been released. https://community.ubnt.com/t5/UniFi-Updates-Blog/UniFi-5-7-23-Stable-has-been-released/ba-p/2318813
Hi there. Looks like Unifi updated to 5.8.24
https://community.ubnt.com/t5/UniFi-Updates-Blog/UniFi-SDN-Controller-5-8-24-Stable-has-been-released/ba-p/2404580
dP21 a dit:
I've been using 5.8 for sometime, though am using 5.9.4 now which is great, though testing only.
Looks like a new version of the controller is available. Please and thank you!
https://community.ubnt.com/t5/UniFi-Updates-Blog/UniFi-SDN-Controller-5-8-28-Stable-has-been-released/ba-p/2449036
QoolBox a dit:
updated to 5.8.28
Thanks for the update.
Can you please comment the upgrade procedure?
With former 5.8.24 version (done twice) I lost my settings and had to restore from backup.
Regards
think you need to backup your setting before update it
i dont use it so dont know where are stored those file, to keep it untouched on update
I supposed in /conf within .qpkg/UniFi directory but not sure... if you can confirm i can probably tweak the installer
QoolBox a dit:
Browsing files in my NAS, it looks like data is stored in <unifi_base>/data/
backup: store manual backups and auto backups
db: seems to store all configuration data.
sites: stores uploaded maps and some sites advanced settings.
Upgrade seems to wipe the db content, and that is why you need to restore.
I can further test.
Hope this makes sense and helps.
Regards
Please, need help from experts on QNAP and Unifi! :)
I'm fighting to run Unifi 5.8.28.0 with QJDK8 1.8.172 at QNAP TS-228A (4.3.3.0695 build 20180830) with no success!
1/ I've first installed QJDK8
2/ follow by Unifi
3/ and when I open Unifi app (http://10.0.0.247:38190) got "failed to open page" error message
I'm new to QNAP world, please let me know what am I doing wrong.
Thanks in advance!
andrelds a dit:
2/ follow by Unifi
Thanks in advance!
it can take longer to run on ARMv8... you need be patient before Unify complete first launch
