QNAP [ Ubiquiti UniFi ] Wi-Fi Management
Merci,
You were correct, I had the wrong version of the QJDK8 after following an old link. Changing that sorted it.
Glyn.
Bonjour Stephane,
Can you please help me out…
I’m wrestling with my Qnap 269L nas to get the Unifi controller working, but so far no luck.
Is there a manual online to sort this out ?
The software i am using:
MongoDB 2.4.4
QJDK 1.8.111
Unify 5.4.15.0
Everything installed without a problem, but when i click on the Unifi icon a new window pops up with adress: http://192.168.2.22:38190 and i get an error – not connection..
Should i use another port ?
Should i change setting on my nas with SHH ?
Can you please help me out ?
Thanks for reading in advance.
Salute Will.
FYI - the filename indicates the version = 5.4.19
However, following installation the Controller reports the version as:
UI 5.5.19.0
Backend 5.5.19
Build atag_5.5.19_9547
Bonjour, quelle est l'adresse, enfin le port à utiliser pour l'inform pour adopter un équipement sur le controlleur?
5.5.21 Stable has been released, https://community.ubnt.com/t5/UniFi-Beta-Blog/UniFi-5-5-21-Stable-Candidate-has-been-released/ba-p/2021171
Can anyone tell me which inform address and more specifically the port number for ap adoption?
Envoyé de mon ONEPLUS A5000 en utilisant Tapatalk
flipper a dit:
I use a Unifi Cloudkey, but its port is on 8443. not sure if this App also is on that port though.
Toxic a dit:
only see 5.5.20 here : https://www.ubnt.com/download/unifi
lets wait some days...
Toxic a dit:
flipper a dit:
Doesn't seem to be this port, that's why I'm asking.... :?
Stephane
Stable release may be stable but but it doesnt fix Krack vulnerabilty. https://www.krackattacks.com/
you may want to reconsider and use Stable Candidate. https://community.ubnt.com/t5/UniFi-Updates-Blog/UniFi-5-6-19-Stable-Candidate-has-been-released/ba-p/2100315
QoolBox a dit:
Hi Simon, will publish it.. didnt know this blog
but strangely 5.6.x is around 100MB less than the 5.5.x ...
it is available on QnapClub Repo
5.6.22 is now out as a Stable Candiate
https://community.ubnt.com/t5/UniFi-Beta-Blog/UniFi-5-6-22-Stable-Candidate-has-been-released/ba-p/2127830
along with UniFi 5.5.27 LTS Stable Candidate
https://community.ubnt.com/t5/UniFi-Beta-Blog/UniFi-5-5-27-LTS-Stable-Candidate-has-been-released/ba-p/2113202
BTW 5.7.x version seems to have EOL limits on same Gen1 AP's.. Discussion about this here:
https://community.ubnt.com/t5/UniFi-Wireless-Beta/EOL-AP-s-in-5-7-x/m-p/2126014
