QNAP [ Ubiquiti UniFi ] Wi-Fi Management
QoolBox a dit:
Hi
please wait for stable.. i have no access to this link
You should have access as it's not in the beta forums anymore.
https://community.ubnt.com/t5/UniFi-Updates-Blog/UniFi-5-6-29-Stable-Candidate-has-been-released/ba-p/2180909
Bonjour a tous et meilleurs voeux pour cette nouvelle année,
j'aurais une question concernant cette derniere version,
sur mon qnap TS-451A , j'ai deja une version installer du controller ( 5.6.19.0 ),
je souhaiterai faire l'update avec la derniere version , mais je ne l'ai jamais fait
et donc souhaiterai savoir comment s'y prendre , dois je le faire depuis le GUI du
controller ou cela doit il se faire dans APP Center du Qnap ?
merci d'avance pour votre aide
joel
QoolBox a dit:
mmmm
look like some instruction are not working on the 32bit version for mongodb...
probably the due to the binary used inside the qpkg bin directory... unfortunately mongodb do not provide mongodb 32bit Linux...
I used some i found in web directory for i686
a bit complicated to make it work.. i think
I've managed to get 5.6.26 (your download) working by replacing the MongoDB files inside bin/ by the latest x86 Linux version: http://downloads.mongodb.org/linux/...50.1653745269.1516662056-719679008.1516662056
DJSnels a dit:
QoolBox a dit:
mmmm
did you get it work with this mongodb release ?
QoolBox a dit:
DJSnels a dit:
QoolBox a dit:
mmmm
Yes. I've used your 5.6.26 qpkg (http://www.qoolbox.fr/Unifi_5.6.26.0_x86.qpkg.zip) to install Unifi. After that i've got the same errors as bino:
F - [initandlisten] Invalid access at address: 0x6ff7
CONTROL [main] ***** SERVER RESTARTED *****
I've replaced all mongodb binaries in bin with the latest x86 verion for Linux and the controller started immediately. :-D
QoolBox a dit:
can you tell me if
www.qoolbox.fr/Unifi_5.6.29.0_x86.qpkg.zip
working ? (clean install will be nice)
I've:
-backed up the current controller through Settings->Maintenance->Backup
-renamed /share/MD0_DATA/.qpkg/Unifi/Unifi (i guess you could change this double Unifi folder in future builds?)
edit: should've backed up the /share/MD0_DATA/.qpkg/Unifi folder, since this one get's deleted entirely on removing the app :-?
-removed Unifi through the App Center
-installed the above 5.6.29 version. Here something strange happened: the progress went to "Installing.....1%", but in the background the usual pop-up "Unifi is installed, a shortcut has been added" appeared. After waiting for 5 minutes the 1% message didn't changed so i refreshed. I went back to the app-center and everything appeared OK. Maby it was just a glitch.
-I've openend unifi and got the standard Setup-wizard.
-I choose to import my 5.6.24 backup
-getting message restore is succesfull, but no redirect or anything. Opening the app again resulted in "this site is not available", the app crashed, time to look at the logs.
Server log (time -1:00h):
[2018-01-23 18:55:45,232] <autoupdate-check> INFO system - firmware[US48P750] new version (3.9.19.8123) is available
[2018-01-23 18:55:45,232] <autoupdate-check> INFO system - firmware[S248500] new version (3.9.19.8123) is available
[2018-01-23 18:55:45,232] <autoupdate-check> INFO system - firmware[S224250] new version (3.9.19.8123) is available
[2018-01-23 19:00:20,482] <webapi-41> INFO db - Connecting to mongodb://127.0.0.1:27117
[2018-01-23 19:00:21,543] <webapi-41> INFO db - Connecting to mongodb://127.0.0.1:27117
[2018-01-23 19:00:24,607] <shutdown-listener> INFO db - waiting for db connection...
[2018-01-23 19:00:24,608] <shutdown-listener> WARN DisposableBeanAdapter - Invocation of destroy method failed on bean with name 'hotspotRadiusService': java.lang.NullPointerException
[2018-01-23 19:00:24,708] <db-server> WARN system - process is interupted: bin/mongod
[2018-01-23 19:00:24,708] <db-server> INFO db - DbServer stopped
mongodb log:
2018-01-23T20:00:24.461+0100 [conn9] CMD: drop ace_stat.stat_minute
2018-01-23T20:00:24.464+0100 [conn9] CMD: drop ace_stat.stat_monthly
2018-01-23T20:00:24.491+0100 [conn9] end connection 127.0.0.1:36677 (6 connections now open)
2018-01-23T20:00:24.492+0100 [conn8] end connection 127.0.0.1:36676 (5 connections now open)
2018-01-23T20:00:24.639+0100 [initandlisten] connection accepted from 127.0.0.1:36687 #10 (6 connections now open)
2018-01-23T20:00:24.682+0100 [initandlisten] connection accepted from 127.0.0.1:36688 #11 (7 connections now open)
2018-01-23T20:00:24.684+0100 [conn11] terminating, shutdown command received
2018-01-23T20:00:24.684+0100 [conn11] dbexit: shutdown called
2018-01-23T20:00:24.684+0100 [conn11] shutdown: going to close listening sockets...
2018-01-23T20:00:24.685+0100 [conn11] closing listening socket: 6
2018-01-23T20:00:24.685+0100 [conn11] closing listening socket: 8
2018-01-23T20:00:24.685+0100 [conn11] removing socket file: /share/MD0_DATA/.qpkg/Unifi/UniFi/run/mongodb-27117.sock
2018-01-23T20:00:24.685+0100 [conn11] shutdown: going to flush diaglog...
2018-01-23T20:00:24.685+0100 [conn11] shutdown: going to close sockets...
2018-01-23T20:00:24.685+0100 [conn11] shutdown: waiting for fs preallocator...
2018-01-23T20:00:24.685+0100 [conn11] shutdown: closing all files...
2018-01-23T20:00:24.690+0100 [conn11] closeAllFiles() finished
2018-01-23T20:00:24.690+0100 [conn11] shutdown: removing fs lock...
2018-01-23T20:00:24.690+0100 [conn11] dbexit: really exiting now
Looks like the DB got a shutdown. But since this mongodb isn't installed as service it didn't start (?)
-i've stopped and started the Unifi app and got a perfectly working controller (these 7 minutes) including my data.
Looks good to me! :-D
5.6.30 stable has been released.
https://community.ubnt.com/t5/UniFi-Updates-Blog/UniFi-5-6-30-Stable-has-been-released/ba-p/2220761
J'ai installé 5.6.35 et j'ai oublié de sauvegarder mon installation 5.6.30. Il semble que l'installation a tout écrasé. Y a-t-il un moyen de récupérer?
Je n'ai pas vu un qpkg d'effacer complètement comme ça, est-ce qu'il serait logique de ne pas écraser le dossier autobackup?
il n'efface rien par défaut lors d'un upgrade....
après je n'utilise pas ce soft.. je ne connais pas son mode de fonctionnement... mais de base le répertoire config est vide ...donc il n'écrase pas de fichiers dans celui-ci...
il fait juste un Append... donc tout fichier présent dans ce répertoire et non présent dans le qpkg doit rester
Hi Stéphane, Unifi Controller 5.7.20 Stable is now available.
https://community.ubnt.com/t5/UniFi-Updates-Blog/UniFi-5-7-20-Stable-has-been-released/ba-p/2271529
When you get a moment, can you do the magic that you do ? :-D
