QNAP [ QBaikal ] [ 0.9.2.0 ] Synchronisateur contacts / calendrier
updated
Added support for php 7.3
REMOVED support for php 5.x
Enabled event invitation plugin
Enabled calendar sharing plugin
Ships with sabre/dav 4.0.1
        $contentType = $propFind->get('{DAV:}getcontenttype');
        list($part) = explode(';', $contentType);
        list($part) = explode(';', $contentType ?: '');
modifcation done in 0.6.0.1
With the 0.7.0 release, our configuration format was updated to use YAML files. You need to go through the installer again but we pre-fill most values with the ones from your old installation. We recommend that you make a full backup of your data, as a safety measure. Starting with 0.7.0, Baikal stores data in both the Specific and the config folders. Keep this in mind when upgrading!
New configuration format
Added support for php 7.4
REMOVED support for php 7.0
Shows event count per calendar
Shows contact count per address book
Ships with sabre/dav 4.1.0
