À tous ceux qui utilisent le fail2ban intégré à SWAG.
J'ai un soucis, aucun de mes fichier .local dans le dossier jail.d n'est pris en compte...
Seul ce que j'ai mis dans le jail.local est pris en compte.
Comment ça se fait ?
Voilà ce que j'ai dans mon jail.local :
Et exemple de fichier pour vaulwarden dans jail.d :
Merci pour le coup de main
INI:
## Version 2020/05/10 - Changelog: https://github.com/linuxserver/docker-swag/commits/master/root/defaults/jail.local
# This is the custom version of the jail.conf for fail2ban
# Feel free to modify this and add additional filters
# Then you can drop the new filter conf files into the fail2ban-filters
# folder and restart the container
## Sources utilisées pour personnaliser ce fichier et ceux dans les sous-dossiers ##
## https://www.linode.com/docs/guides/using-fail2ban-to-secure-your-server-a-tutorial/ ##
## https://www.linuxtricks.fr/wiki/print.php?id=40 ##
[DEFAULT]
# "ignoreip" can be an IP address, a CIDR mask or a DNS host. Fail2ban will not
# ban a host which matches an address in this list. Several addresses can be
# defined using space separator.
ignoreip = 127.0.0.1/8 ::1
10.0.0.0/8
192.168.0.0/16
172.16.0.0/12
# Changes the default ban action from "iptables-multiport", which causes issues on some platforms, to "iptables-allports".
banaction = %(banaction_allports)s
# "bantime.increment" allows to use database for searching of previously banned ip's to increase a
# default ban time
bantime.increment = true
# "bantime.maxtime" is the max number of seconds using the ban time can reach (doesn't grow further)
bantime.maxtime = 5w
# "bantime.factor" is a coefficient to calculate exponent growing of the formula or common multiplier
bantime.factor = 24
# "bantime" is the number of seconds that a host is banned.
bantime = 1h
# A host is banned if it has generated "maxretry" during the last "findtime"
# seconds.
findtime = 24h
# "maxretry" is the number of failures before a host get banned.
maxretry = 5
# eMail config
destemail = mon-email@gmail.com
dest = mon-email@gmail.com
sender = mon-email@gmail.com
sendername = Fail2Ban (SWAG)
# ban & send an e-mail with whois report and relevant log lines
# to the destemail.
action = %(action_mwl)s
# Notes.: command executed on demand at the first ban (or at the start of Fail2Ban if actionstart_on_demand is set to false).
actionstart = printf %%b "Subject: [Fail2Ban (SWAG)] <name>: started on <fq-hostname>
Date: `LC_ALL=C date +"%%a, %%d %%h %%Y %%T %%z"`
To: <dest>\n
Hi,\n
The jail <name> has been started successfully.\n
Regards,\n
Fail2Ban (SWAG)" | <mailcmd>
# Notes.: command executed at the stop of jail (or at the end of Fail2Ban)
actionstop = printf %%b "Subject: [Fail2Ban (SWAG)] <name>: stopped on <fq-hostname>
To: <dest>\n
Hi,\n
The jail <name> has been stopped.\n
Regards,\n
backend = auto
[ssh]
enabled = true
port = 99 # Valeur du port si changer, sinon ssh
filter = sshd
logpath = /log/host_ssh_auth.log
[nginx-http-auth]
enabled = true
filter = nginx-http-auth
port = http,https
logpath = /config/log/nginx/error.log
[nginx-badbots]
enabled = true
port = http,https
filter = nginx-badbots
logpath = /config/log/nginx/access.log
maxretry = 2
[nginx-botsearch]
enabled = true
port = http,https
filter = nginx-botsearch
[nginx-deny]
enabled = false
port = http,https
filter = nginx-deny
[nginx-unauthorized]
enabled = true
port = http,https
filter = nginx-unauthorized
logpath = /config/log/nginx/unauthorized.log
INI:
## /volume1/docker/swag_macvlan/fail2ban/jail.d/vaultwarden-auth.conf
## See : https://github.com/dani-garcia/vaultwarden/wiki/Fail2Ban-Setup#synology-dsm
## Version 2022/08/06
# Fail2Ban jail configuration for vaultwarden
# Requires modification to Vaultwarden's settings
# https://github.com/dani-garcia/vaultwarden/wiki/Logging#logging-to-a-file
[vaultwarden-auth]
enabled = true
port = 882,443,3012
# Doit correspondre au nom du fichier .conf dans le dossier filter.d
filter = vaultwarden-auth
logpath = /var/log/vaultwarden.log
maxretry = 3
bantime = 14400
findtime = 14400
