2021-04-17 17:21:18,685 main ERROR Unable to locate appender "InMemoryAppender" for logger config "root",
org.tuckey.web.filters.urlrewrite.UrlRewriteFilter INFO: destroy called,
[cont-finish.d] executing container finish scripts...,
[cont-finish.d] done.,
[s6-finish] waiting for services.,
[s6-finish] sending all processes the TERM signal.,
[s6-finish] sending all processes the KILL signal and exiting.,
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.,
[s6-init] ensuring user provided files have correct perms...exited 0.,
[fix-attrs.d] applying ownership & permissions fixes...,
[fix-attrs.d] done.,
[cont-init.d] executing container initialization scripts...,
[cont-init.d] 01-envfile: executing... ,
[cont-init.d] 01-envfile: exited 0.,
[cont-init.d] 10-adduser: executing... ,
usermod: no changes,
_ (),
| | ___ _ __,
| | / __| | | / \ ,
| | \__ \ | | | () |,
|_| |___/ |_| \__/,
Brought to you by linuxserver.io,
To support LSIO projects visit:,
https://www.linuxserver.io/donate/,
GID/UID,
User uid: 911,
User gid: 911,
[cont-init.d] 10-adduser: exited 0.,
[cont-init.d] 20-config: executing... ,
[cont-init.d] 20-config: exited 0.,
[cont-init.d] 30-keygen: executing... ,
[cont-init.d] 30-keygen: exited 0.,
[cont-init.d] 99-custom-scripts: executing... ,
[custom-init] no custom files found exiting...,
[cont-init.d] 99-custom-scripts: exited 0.,
[cont-init.d] done.,
[services.d] starting services,
[services.d] done.,
2021-04-18 06:41:25,412 main ERROR Error processing element InMemoryAppender ([Appenders: null]): CLASS_NOT_FOUND,
2021-04-18 06:41:26,684 main ERROR Unable to locate appender "InMemoryAppender" for logger config "root",
_ (),
| | ___ _ __,
| | / __| | | / \ ,
| | \__ \ | | | () |,
|_| |___/ |_| \__/,
GID/UID,
User uid: 911,
User gid: 911,
[services.d] done.,
2021-04-18 09:02:02,919 main ERROR Error processing element InMemoryAppender ([Appenders: null]): CLASS_NOT_FOUND,
2021-04-18 09:02:04,595 main ERROR Unable to locate appender "InMemoryAppender" for logger config "root",
