[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 01-envfile: executing...
[cont-init.d] 01-envfile: exited 0.
[cont-init.d] 10-adduser: executing...
_ ()
| | ___ _ __
| | / __| | | / \
| | \__ \ | | | () |
|_| |___/ |_| \__/
Brought to you by linuxserver.io
https://www.linuxserver.io/donate/
GID/UID
User uid: 1026
User gid: 100
[cont-init.d] 10-adduser: exited 0.
[cont-init.d] 20-config: executing...
[cont-init.d] 20-config: exited 0.
[cont-init.d] 30-keygen: executing...
generating self-signed keys in /config/keys, you can replace these with your own keys if required
Generating a RSA private key
writing new private key to '/config/keys/cert.key'
[cont-init.d] 30-keygen: exited 0.
[cont-init.d] 40-config: executing...
Starting 2019/12/30, GeoIP2 databases require personal license key to download. Please manually download/update the GeoIP2 db and save as /config/geoip2db/GeoLite2-City.mmdb
[cont-init.d] 40-config: exited 0.
[cont-init.d] 50-speedtest: executing...
Ookla GDPR and EULA accepted. Downloading Speedtest CLI.
Connecting to install.speedtest.net (151.101.2.219:443)
saving to 'speedtest.tgz'
speedtest.tgz 21% |****** | 192k 0:00:03 ETA
speedtest.tgz 100% |********************************| 908k 0:00:00 ETA
'speedtest.tgz' saved
You may only use this Speedtest software and information generated
from it for personal, non-commercial use, through a command line
interface on a personal computer. Your use of this software is subject
to the End User License Agreement, Terms of Use and Privacy Policy at
these URLs:
https://www.speedtest.net/about/eula
https://www.speedtest.net/about/terms
https://www.speedtest.net/about/privacy
License acceptance recorded. Continuing.
Ookla collects certain data through Speedtest that may be considered
personally identifiable, such as your IP address, unique device
identifiers or location. Ookla believes it has a legitimate interest
to share this data with internet providers, hardware manufacturers and
industry regulators to help them understand and create a better and
faster internet. For further information including how the data may be
shared, where the data may be transferred and Ookla's contact details,
please see our Privacy Policy at:
http://www.speedtest.net/privacy
Copying latest site files to config
Database file not found! Creating empty database
Env file not found! Creating .env file
Running database migrations
Migration table created successfully.
Migrating: 2014_10_12_000000_create_users_table
Migrated: 2014_10_12_000000_create_users_table (0.42 seconds)
Migrating: 2019_08_19_000000_create_failed_jobs_table
Migrated: 2019_08_19_000000_create_failed_jobs_table (0.13 seconds)
Migrating: 2020_04_03_104234_create_email_verifications_table
Migrated: 2020_04_03_104234_create_email_verifications_table (0.11 seconds)
Migrating: 2020_04_03_105113_create_active_sessions_table
Migrated: 2020_04_03_105113_create_active_sessions_table (0.11 seconds)
Migrating: 2020_04_08_120837_create_speedtests_table
Migrated: 2020_04_08_120837_create_speedtests_table (0.09 seconds)
Migrating: 2020_04_08_125647_create_jobs_table
Migrated: 2020_04_08_125647_create_jobs_table (0.18 seconds)
Migrating: 2020_05_18_211812_create_settings_table
Migrated: 2020_05_18_211812_create_settings_table (0.36 seconds)
Migrating: 2020_06_20_164502_update_speedtests_table
Migrated: 2020_06_20_164502_update_speedtests_table (0.27 seconds)
Migrating: 2020_06_21_171849_add_notifications_settings
Migrated: 2020_06_21_171849_add_notifications_settings (0.2 seconds)
Migrating: 2020_06_28_235331_update_speedtests_add_manual_column
Migrated: 2020_06_28_235331_update_speedtests_add_manual_column (0.07 seconds)
Migrating: 2020_07_03_095049_update_speedtest_add_failed_column
Migrated: 2020_07_03_095049_update_speedtest_add_failed_column (0.07 seconds)
Migrating: 2020_07_06_105930_add_graph_settings
Migrated: 2020_07_06_105930_add_graph_settings (0.46 seconds)
Migrating: 2020_07_07_215412_add_notification_agent_settings
Migrated: 2020_07_07_215412_add_notification_agent_settings (0.19 seconds)
Migrating: 2020_08_12_123941_add_healthchecks_settings
Migrated: 2020_08_12_123941_add_healthchecks_settings (0.13 seconds)
Migrating: 2020_08_21_133343_add_authentication_settings
Migrated: 2020_08_21_133343_add_authentication_settings (0.06 seconds)
Migrating: 2020_08_21_204656_add_conditional_notifications_settings
Migrated: 2020_08_21_204656_add_conditional_notifications_settings (0.39 seconds)
Migrating: 2020_08_28_192136_add_show_failed_tests_setting
Migrated: 2020_08_28_192136_add_show_failed_tests_setting (0.09 seconds)
Migrating: 2020_09_10_231121_add_widget_card_settings
Migrated: 2020_09_10_231121_add_widget_card_settings (0.23 seconds)
Migrating: 2020_12_19_211232_add_schedule_enabled_setting
Migrated: 2020_12_19_211232_add_schedule_enabled_setting (0.06 seconds)
Migrating: 2020_12_19_234248_add_app_name_setting
Migrated: 2020_12_19_234248_add_app_name_setting (0.08 seconds)
Migrating: 2020_12_20_001345_add_custom_healthchecks_setting
Migrated: 2020_12_20_001345_add_custom_healthchecks_setting (0.07 seconds)
Generating app key
Application key set successfully.
Generating JWT secret
jwt-auth secret [ouVkXAjjBBglNKDfmOJ3gDbTLKI68f5DCbuc1p5wezM5Zxpn1EvwEAdz8eIyHrd4] set successfully.
Slack webhook is unset
Telegram chat id and bot token unset
Base path is unset
AUTH variable not set. Disabling authentication
Clearing old jobs from queue
[cont-init.d] 50-speedtest: exited 0.
[cont-init.d] 99-custom-files: executing...
[custom-init] no custom files found exiting...
[cont-init.d] 99-custom-files: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
{"type":"log","timestamp":"2021-08-10T04:05:04Z","message":"Error: [104] Cannot read from socket: Connection reset by peer","level":"error"}
[cont-finish.d] executing container finish scripts...
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
[s6-finish] sending all processes the KILL signal and exiting.
[fix-attrs.d] done.
usermod: no changes
_ ()
| | ___ _ __
| | / __| | | / \
| | \__ \ | | | () |
|_| |___/ |_| \__/
GID/UID
User uid: 1026
User gid: 100
using keys found in /config/keys
Database file exists
Env file exists
Nothing to migrate.
App key exists
JWT secret exists
Base path is unset
[cont-init.d] done.
[services.d] done.
[fix-attrs.d] done.
usermod: no changes
_ ()
| | ___ _ __
| | / __| | | / \
| | \__ \ | | | () |
|_| |___/ |_| \__/
GID/UID
User uid: 1026
User gid: 100
Env file exists
Nothing to migrate.
App key exists
JWT secret exists
Base path is unset
[cont-init.d] done.
[services.d] done.
[2021-08-11 09:08:28.490] [error] Configuration - Couldn't resolve host name (HostNotFoundException)
[2021-08-11 09:08:28.490] [error] Configuration - Cannot retrieve configuration document (0)
[2021-08-11 09:08:28.490] [error] ConfigurationError - Could not retrieve or read configuration (Configuration)
{"type":"log","timestamp":"2021-08-11T07:08:28Z","message":"Configuration - Could not retrieve or read configuration (ConfigurationError)","level":"error"}
[2021-08-11 09:08:47.221] [error] Configuration - Couldn't resolve host name (HostNotFoundException)
[2021-08-11 09:08:47.221] [error] Configuration - Cannot retrieve configuration document (0)
[2021-08-11 09:08:47.221] [error] ConfigurationError - Could not retrieve or read configuration (Configuration)
{"type":"log","timestamp":"2021-08-11T07:08:47Z","message":"Configuration - Could not retrieve or read configuration (ConfigurationError)","level":"error"}
{"type":"log","timestamp":"2021-08-11T08:00:11Z","message":"Error: [11] Cannot read: Resource temporarily unavailable","level":"error"}
{"type":"log","timestamp":"2021-08-11T08:00:12Z","message":"Error: [11] Cannot read: Resource temporarily unavailable","level":"error"}
[fix-attrs.d] done.
usermod: no changes
_ ()
| | ___ _ __
| | / __| | | / \
| | \__ \ | | | () |
|_| |___/ |_| \__/
GID/UID
User uid: 1026
User gid: 100
Env file exists
Nothing to migrate.
App key exists
JWT secret exists
Base path is unset
[cont-init.d] done.
[services.d] done.
{"type":"log","timestamp":"2021-08-11T10:08:38Z","message":"Error: [11] Cannot read: Resource temporarily unavailable","level":"error"}
[fix-attrs.d] done.
usermod: no changes
_ ()
| | ___ _ __
| | / __| | | / \
| | \__ \ | | | () |
|_| |___/ |_| \__/
GID/UID
User uid: 1026
User gid: 100
Env file exists
Nothing to migrate.
App key exists
JWT secret exists
Base path is unset
[cont-init.d] done.
[services.d] done.
{"type":"log","timestamp":"2021-08-11T13:05:15Z","message":"Error: [11] Cannot read: Resource temporarily unavailable","level":"error"}
{"type":"log","timestamp":"2021-08-12T13:00:05Z","message":"Error: [11] Cannot read from socket: Resource temporarily unavailable","level":"error"}
[2021-08-13 19:50:29.770] [error] Configuration - Couldn't connect to server (Network is unreachable)
[2021-08-13 19:50:29.770] [error] Configuration - Cannot retrieve configuration document (0)
[2021-08-13 19:50:29.770] [error] ConfigurationError - Could not retrieve or read configuration (Configuration)
[2021-08-13 19:50:29.771] [error] ConfigurationError - Could not retrieve or read configuration (Configuration)
{"type":"log","timestamp":"2021-08-13T17:50:29Z","message":"Configuration - Could not retrieve or read configuration (ConfigurationError)","level":"error"}
[2021-08-13 19:51:28.630] [error] Configuration - Couldn't connect to server (Network is unreachable)
[2021-08-13 19:51:28.630] [error] Configuration - Cannot retrieve configuration document (0)
[2021-08-13 19:51:28.630] [error] ConfigurationError - Could not retrieve or read configuration (Configuration)
[2021-08-13 19:51:28.631] [error] ConfigurationError - Could not retrieve or read configuration (Configuration)
{"type":"log","timestamp":"2021-08-13T17:51:28Z","message":"Configuration - Could not retrieve or read configuration (ConfigurationError)","level":"error"}
[fix-attrs.d] done.
usermod: no changes
_ ()
| | ___ _ __
| | / __| | | / \
| | \__ \ | | | () |
|_| |___/ |_| \__/
GID/UID
User uid: 1026
User gid: 100
Env file exists
Nothing to migrate.
App key exists
JWT secret exists
Base path is unset
[cont-init.d] done.
[services.d] done.
[2021-08-13 19:52:55.702] [error] Configuration - Couldn't connect to server (Network is unreachable)
[2021-08-13 19:52:55.702] [error] Configuration - Cannot retrieve configuration document (0)
[2021-08-13 19:52:55.702] [error] ConfigurationError - Could not retrieve or read configuration (Configuration)
[2021-08-13 19:52:55.703] [error] ConfigurationError - Could not retrieve or read configuration (Configuration)
{"type":"log","timestamp":"2021-08-13T17:52:55Z","message":"Configuration - Could not retrieve or read configuration (ConfigurationError)","level":"error"}
[2021-08-13 19:53:54.686] [error] Configuration - Couldn't connect to server (Network is unreachable)
[2021-08-13 19:53:54.686] [error] Configuration - Cannot retrieve configuration document (0)
[2021-08-13 19:53:54.686] [error] ConfigurationError - Could not retrieve or read configuration (Configuration)
[2021-08-13 19:53:54.687] [error] ConfigurationError - Could not retrieve or read configuration (Configuration)
{"type":"log","timestamp":"2021-08-13T17:53:54Z","message":"Configuration - Could not retrieve or read configuration (ConfigurationError)","level":"error"}
[fix-attrs.d] done.
usermod: no changes
_ ()
| | ___ _ __
| | / __| | | / \
| | \__ \ | | | () |
|_| |___/ |_| \__/
GID/UID
User uid: 1026
User gid: 100
Env file exists
Nothing to migrate.
App key exists
JWT secret exists
Base path is unset
[cont-init.d] done.
[services.d] done.
[2021-08-13 19:55:25.822] [error] Configuration - Couldn't connect to server (Network is unreachable)
[2021-08-13 19:55:25.822] [error] Configuration - Cannot retrieve configuration document (0)
[2021-08-13 19:55:25.822] [error] ConfigurationError - Could not retrieve or read configuration (Configuration)
[2021-08-13 19:55:25.823] [error] ConfigurationError - Could not retrieve or read configuration (Configuration)
{"type":"log","timestamp":"2021-08-13T17:55:25Z","message":"Configuration - Could not retrieve or read configuration (ConfigurationError)","level":"error"}
[2021-08-13 19:56:27.430] [error] Configuration - Couldn't connect to server (Network is unreachable)
[2021-08-13 19:56:27.430] [error] Configuration - Cannot retrieve configuration document (0)
[2021-08-13 19:56:27.430] [error] ConfigurationError - Could not retrieve or read configuration (Configuration)
[2021-08-13 19:56:27.431] [error] ConfigurationError - Could not retrieve or read configuration (Configuration)
{"type":"log","timestamp":"2021-08-13T17:56:27Z","message":"Configuration - Could not retrieve or read configuration (ConfigurationError)","level":"error"}
[2021-08-13 19:57:45.462] [error] Configuration - Couldn't connect to server (Network is unreachable)
[2021-08-13 19:57:45.462] [error] Configuration - Cannot retrieve configuration document (0)
[2021-08-13 19:57:45.462] [error] ConfigurationError - Could not retrieve or read configuration (Configuration)
[2021-08-13 19:57:45.463] [error] ConfigurationError - Could not retrieve or read configuration (Configuration)
{"type":"log","timestamp":"2021-08-13T17:57:45Z","message":"Configuration - Could not retrieve or read configuration (ConfigurationError)","level":"error"}
[2021-08-13 20:00:15.894] [error] Configuration - Couldn't connect to server (Network is unreachable)
[2021-08-13 20:00:15.894] [error] Configuration - Cannot retrieve configuration document (0)
[2021-08-13 20:00:15.895] [error] ConfigurationError - Could not retrieve or read configuration (Configuration)
[2021-08-13 20:00:15.896] [error] ConfigurationError - Could not retrieve or read configuration (Configuration)
{"type":"log","timestamp":"2021-08-13T18:00:15Z","message":"Configuration - Could not retrieve or read configuration (ConfigurationError)","level":"error"}
No MaxMind license key found; exiting. Please enter your license key into /etc/conf.d/libmaxminddb
run-parts: /etc/periodic/weekly/libmaxminddb: exit status 1
{"type":"log","timestamp":"2021-08-14T20:00:43Z","message":"Trying to get interface information on non-initialized socket.","level":"error"}
{"type":"log","timestamp":"2021-08-15T06:00:07Z","message":"Error: [11] Cannot read: Resource temporarily unavailable","level":"error"}
{"type":"log","timestamp":"2021-08-15T22:30:07Z","message":"Error: [11] Cannot read from socket: Resource temporarily unavailable","level":"error"}
[2021-08-17 20:30:08.331] [error] Configuration - Couldn't resolve host name (HostNotFoundException)
[2021-08-17 20:30:08.331] [error] Configuration - Cannot retrieve configuration document (0)
[2021-08-17 20:30:08.331] [error] ConfigurationError - Could not retrieve or read configuration (Configuration)
{"type":"log","timestamp":"2021-08-17T18:30:08Z","message":"Configuration - Could not retrieve or read configuration (ConfigurationError)","level":"error"}
{"type":"log","timestamp":"2021-08-18T10:30:40Z","message":"Trying to get interface information on non-initialized socket.","level":"error"}
{"type":"log","timestamp":"2021-08-20T02:30:04Z","message":"Error: [104] Cannot read from socket: Connection reset by peer","level":"error"}
[fix-attrs.d] done.
usermod: no changes
_ ()
| | ___ _ __
| | / __| | | / \
| | \__ \ | | | () |
|_| |___/ |_| \__/
GID/UID
User uid: 1026
User gid: 100
Env file exists
Nothing to migrate.
App key exists
JWT secret exists
Base path is unset
[cont-init.d] done.
[services.d] done.
[fix-attrs.d] done.
usermod: no changes
_ ()
| | ___ _ __
| | / __| | | / \
| | \__ \ | | | () |
|_| |___/ |_| \__/
GID/UID
User uid: 1026
User gid: 100
Env file exists
Nothing to migrate.
App key exists
JWT secret exists
Base path is unset
[cont-init.d] done.
[services.d] done.
wget: bad address 'geolite.maxmind.com'
run-parts: /etc/periodic/monthly/geoip: exit status 1
[2021-09-01 12:00:04.108] [error] Limit reached:
<html>
<head><title>429 Too Many Requests</title></head>
<body>
<center><h1>429 Too Many Requests</h1></center>
<hr><center>openresty</center>
</body>
</html>
[2021-09-01 12:30:02.590] [error] Limit reached:
<html>
<body>
</body>
</html>
[2021-09-01 13:00:04.163] [error] Limit reached:
<html>
<body>
</body>
</html>
[2021-09-01 13:30:03.236] [error] Limit reached:
<html>
<body>
</body>
</html>
[2021-09-01 14:00:03.180] [error] Limit reached:
<html>
<body>
</body>
</html>
[2021-09-01 14:30:05.045] [error] Limit reached:
<html>
<body>
</body>
</html>
[2021-09-01 15:00:03.634] [error] Limit reached:
<html>
<body>
</body>
</html>
[2021-09-01 15:30:03.691] [error] Limit reached:
<html>
<body>
</body>
</html>
[2021-09-01 16:00:04.038] [error] Limit reached:
<html>
<body>
</body>
</html>
[2021-09-01 16:24:05.590] [error] Limit reached:
<html>
<body>
</body>
</html>
[2021-09-01 16:30:03.730] [error] Limit reached:
<html>
<body>
</body>
</html>
[fix-attrs.d] done.
usermod: no changes
_ ()
| | ___ _ __
| | / __| | | / \
| | \__ \ | | | () |
|_| |___/ |_| \__/
GID/UID
User uid: 1026
User gid: 100
[2021-09-01 16:56:30.048] [error] Limit reached:
<html>
<body>
</body>
</html>
Env file exists
Nothing to migrate.
App key exists
JWT secret exists
Base path is unset
[cont-init.d] done.
[services.d] done.
{"type":"log","timestamp":"2021-09-02T11:30:06Z","message":"Error: [11] Cannot read from socket: Resource temporarily unavailable","level":"error"}
{"type":"log","timestamp":"2021-09-04T11:00:43Z","message":"Trying to get interface information on non-initialized socket.","level":"error"}
[fix-attrs.d] done.
usermod: no changes
_ ()
| | ___ _ __
| | / __| | | / \
| | \__ \ | | | () |
|_| |___/ |_| \__/
GID/UID
User uid: 1026
User gid: 100
Env file exists
Nothing to migrate.
App key exists
JWT secret exists
Base path is unset
[cont-init.d] done.
[services.d] done.
{"type":"log","timestamp":"2021-09-05T23:00:09Z","message":"Error: [110] Cannot open socket: Timeout occurred in connect.","level":"error"}
[fix-attrs.d] done.
usermod: no changes
_ ()
| | ___ _ __
| | / __| | | / \
| | \__ \ | | | () |
|_| |___/ |_| \__/
GID/UID
User uid: 1026
User gid: 100
Env file exists
Nothing to migrate.
App key exists
JWT secret exists
Base path is unset
[cont-init.d] done.
[services.d] done.
