Pour offrir le choix a celui qu'il l'install. Pour ma part je n'utilise que rutorrent.pourquoi dans la stack avoir rutorrent + qbittorrent?
sysctls:
- net.ipv6.conf.all.disable_ipv6=1
WARNING: ip6tables disabled!
Run 'sudo modprobe ip6table_filter' on your host
modprobe: can't change directory to '/lib/modules': No such file or directory
ip6tables v1.8.4 (legacy): can't initialize ip6tables table `nat': Table does not exist (do you need to insmod?)
Perhaps ip6tables or your kernel needs to be upgraded.
The use of ROUTE or -r may no longer be needed, try it without!
Dump terminated
+ exec sg vpn -c 'openvpn --cd /vpn --config /vpn/openvpn.ovpn --script-security 2 --redirect-gateway def1 --route-up '\''/bin/sh -c " iptables -A OUTPUT -d 127.0.0.11 -j ACCEPT"'\'' --route-pre-down '\''/bin/sh -c " iptables -D OUTPUT -d 127.0.0.11 -j ACCEPT"'\'' --auth-user-pass /vpn/vpn.auth '
Sun Feb 26 15:31:13 2023 us=455399 WARNING: file 'client.key' is group or others accessible
Sun Feb 26 15:31:13 2023 us=455759 WARNING: file '/vpn/vpn.auth' is group or others accessible
Sun Feb 26 15:31:13 2023 us=455795 Current Parameter Settings:
Sun Feb 26 15:31:13 2023 us=455804 config = '/vpn/openvpn.ovpn'
Sun Feb 26 15:31:13 2023 us=455811 mode = 0
Sun Feb 26 15:31:13 2023 us=455818 persist_config = DISABLED
Sun Feb 26 15:31:13 2023 us=455826 persist_mode = 1
Sun Feb 26 15:31:13 2023 us=455833 show_ciphers = DISABLED
Sun Feb 26 15:31:13 2023 us=455839 show_digests = DISABLED
Sun Feb 26 15:31:13 2023 us=455847 show_engines = DISABLED
Sun Feb 26 15:31:13 2023 us=455855 genkey = DISABLED
Sun Feb 26 15:31:13 2023 us=455863 key_pass_file = '[UNDEF]'
Sun Feb 26 15:31:13 2023 us=455869 show_tls_ciphers = DISABLED
Sun Feb 26 15:31:13 2023 us=455876 connect_retry_max = 0
Sun Feb 26 15:31:13 2023 us=455883 Connection profiles [0]:
Sun Feb 26 15:31:13 2023 us=455898 proto = udp
Sun Feb 26 15:31:13 2023 us=455905 local = '[UNDEF]'
Sun Feb 26 15:31:13 2023 us=455912 local_port = '[UNDEF]'
Sun Feb 26 15:31:13 2023 us=455920 remote = '87-1-fr.cg-dialup.net'
Sun Feb 26 15:31:13 2023 us=455927 remote_port = '443'
Sun Feb 26 15:31:13 2023 us=455934 remote_float = DISABLED
Sun Feb 26 15:31:13 2023 us=455940 bind_defined = DISABLED
Sun Feb 26 15:31:13 2023 us=455947 bind_local = DISABLED
Sun Feb 26 15:31:13 2023 us=455957 bind_ipv6_only = DISABLED
Sun Feb 26 15:31:13 2023 us=455963 connect_retry_seconds = 5
Sun Feb 26 15:31:13 2023 us=455970 connect_timeout = 120
Sun Feb 26 15:31:13 2023 us=455976 socks_proxy_server = '[UNDEF]'
Sun Feb 26 15:31:13 2023 us=455982 socks_proxy_port = '[UNDEF]'
Sun Feb 26 15:31:13 2023 us=455989 tun_mtu = 1500
Sun Feb 26 15:31:13 2023 us=456008 tun_mtu_defined = ENABLED
Sun Feb 26 15:31:13 2023 us=456015 link_mtu = 1500
Sun Feb 26 15:31:13 2023 us=456022 link_mtu_defined = DISABLED
Sun Feb 26 15:31:13 2023 us=456028 tun_mtu_extra = 0
Sun Feb 26 15:31:13 2023 us=456035 tun_mtu_extra_defined = DISABLED
Sun Feb 26 15:31:13 2023 us=456042 mtu_discover_type = -1
Sun Feb 26 15:31:13 2023 us=456049 fragment = 0
Sun Feb 26 15:31:13 2023 us=456056 mssfix = 1450
Sun Feb 26 15:31:13 2023 us=456063 explicit_exit_notification = 2
Sun Feb 26 15:31:13 2023 us=456069 Connection profiles END
Sun Feb 26 15:31:13 2023 us=456088 remote_random = DISABLED
Sun Feb 26 15:31:13 2023 us=456096 ipchange = '[UNDEF]'
Sun Feb 26 15:31:13 2023 us=456103 dev = 'tun'
Sun Feb 26 15:31:13 2023 us=456110 dev_type = '[UNDEF]'
Sun Feb 26 15:31:13 2023 us=456117 dev_node = '[UNDEF]'
Sun Feb 26 15:31:13 2023 us=456124 lladdr = '[UNDEF]'
Sun Feb 26 15:31:13 2023 us=456131 topology = 1
Sun Feb 26 15:31:13 2023 us=456138 ifconfig_local = '[UNDEF]'
Sun Feb 26 15:31:13 2023 us=456156 ifconfig_remote_netmask = '[UNDEF]'
Sun Feb 26 15:31:13 2023 us=456163 ifconfig_noexec = DISABLED
Sun Feb 26 15:31:13 2023 us=456170 ifconfig_nowarn = DISABLED
Sun Feb 26 15:31:13 2023 us=456177 ifconfig_ipv6_local = '[UNDEF]'
Sun Feb 26 15:31:13 2023 us=456185 ifconfig_ipv6_netbits = 0
Sun Feb 26 15:31:13 2023 us=456191 ifconfig_ipv6_remote = '[UNDEF]'
Sun Feb 26 15:31:13 2023 us=456198 shaper = 0
Sun Feb 26 15:31:13 2023 us=456230 mtu_test = 0
Sun Feb 26 15:31:13 2023 us=456238 mlock = DISABLED
Sun Feb 26 15:31:13 2023 us=456246 keepalive_ping = 0
Sun Feb 26 15:31:13 2023 us=456253 keepalive_timeout = 0
Sun Feb 26 15:31:13 2023 us=456260 inactivity_timeout = 0
Sun Feb 26 15:31:13 2023 us=456266 ping_send_timeout = 5
Sun Feb 26 15:31:13 2023 us=456274 ping_rec_timeout = 60
Sun Feb 26 15:31:13 2023 us=456282 ping_rec_timeout_action = 1
Sun Feb 26 15:31:13 2023 us=456289 ping_timer_remote = ENABLED
Sun Feb 26 15:31:13 2023 us=456296 remap_sigusr1 = 0
Sun Feb 26 15:31:13 2023 us=456303 persist_tun = ENABLED
Sun Feb 26 15:31:13 2023 us=456309 persist_local_ip = DISABLED
Sun Feb 26 15:31:13 2023 us=456316 persist_remote_ip = DISABLED
Sun Feb 26 15:31:13 2023 us=456322 persist_key = ENABLED
Sun Feb 26 15:31:13 2023 us=456330 passtos = DISABLED
Sun Feb 26 15:31:13 2023 us=456351 resolve_retry_seconds = 1000000000
Sun Feb 26 15:31:13 2023 us=456359 resolve_in_advance = DISABLED
Sun Feb 26 15:31:13 2023 us=456366 username = '[UNDEF]'
Sun Feb 26 15:31:13 2023 us=456374 groupname = '[UNDEF]'
Sun Feb 26 15:31:13 2023 us=456381 chroot_dir = '[UNDEF]'
Sun Feb 26 15:31:13 2023 us=456396 cd_dir = '/vpn'
Sun Feb 26 15:31:13 2023 us=456403 writepid = '[UNDEF]'
Sun Feb 26 15:31:13 2023 us=456410 up_script = '[UNDEF]'
Sun Feb 26 15:31:13 2023 us=456418 down_script = '[UNDEF]'
Sun Feb 26 15:31:13 2023 us=456425 down_pre = DISABLED
Sun Feb 26 15:31:13 2023 us=456431 up_restart = DISABLED
Sun Feb 26 15:31:13 2023 us=456438 up_delay = DISABLED
Sun Feb 26 15:31:13 2023 us=456453 daemon = DISABLED
Sun Feb 26 15:31:13 2023 us=456460 inetd = 0
Sun Feb 26 15:31:13 2023 us=456467 log = DISABLED
Sun Feb 26 15:31:13 2023 us=456474 suppress_timestamps = DISABLED
Sun Feb 26 15:31:13 2023 us=456481 machine_readable_output = DISABLED
Sun Feb 26 15:31:13 2023 us=456488 nice = 0
Sun Feb 26 15:31:13 2023 us=456494 verbosity = 4
Sun Feb 26 15:31:13 2023 us=456501 mute = 0
Sun Feb 26 15:31:13 2023 us=456521 gremlin = 0
Sun Feb 26 15:31:13 2023 us=456529 status_file = '[UNDEF]'
Sun Feb 26 15:31:13 2023 us=456535 status_file_version = 1
Sun Feb 26 15:31:13 2023 us=456542 status_file_update_freq = 60
Sun Feb 26 15:31:13 2023 us=456548 occ = ENABLED
Sun Feb 26 15:31:13 2023 us=456556 rcvbuf = 0
Sun Feb 26 15:31:13 2023 us=456563 sndbuf = 0
Sun Feb 26 15:31:13 2023 us=456569 mark = 0
Sun Feb 26 15:31:13 2023 us=456576 sockflags = 0
Sun Feb 26 15:31:13 2023 us=456582 fast_io = DISABLED
Sun Feb 26 15:31:13 2023 us=456592 comp.alg = 0
Sun Feb 26 15:31:13 2023 us=456598 comp.flags = 0
Sun Feb 26 15:31:13 2023 us=456606 route_script = '/bin/sh -c " iptables -A OUTPUT -d 127.0.0.11 -j ACCEPT"'
Sun Feb 26 15:31:13 2023 us=456612 route_default_gateway = '[UNDEF]'
Sun Feb 26 15:31:13 2023 us=456619 route_default_metric = 0
Sun Feb 26 15:31:13 2023 us=456626 route_noexec = DISABLED
Sun Feb 26 15:31:13 2023 us=456643 route_delay = 5
Sun Feb 26 15:31:13 2023 us=456650 route_delay_window = 30
Sun Feb 26 15:31:13 2023 us=456658 route_delay_defined = ENABLED
Sun Feb 26 15:31:13 2023 us=456665 route_nopull = DISABLED
Sun Feb 26 15:31:13 2023 us=456672 route_gateway_via_dhcp = DISABLED
Sun Feb 26 15:31:13 2023 us=456679 allow_pull_fqdn = DISABLED
Sun Feb 26 15:31:13 2023 us=456687 [redirect_default_gateway local=0]
Sun Feb 26 15:31:13 2023 us=456694 management_addr = '[UNDEF]'
Sun Feb 26 15:31:13 2023 us=456710 management_port = '[UNDEF]'
Sun Feb 26 15:31:13 2023 us=456718 management_user_pass = '[UNDEF]'
Sun Feb 26 15:31:13 2023 us=456725 management_log_history_cache = 250
Sun Feb 26 15:31:13 2023 us=456732 management_echo_buffer_size = 100
Sun Feb 26 15:31:13 2023 us=456740 management_write_peer_info_file = '[UNDEF]'
Sun Feb 26 15:31:13 2023 us=456746 management_client_user = '[UNDEF]'
Sun Feb 26 15:31:13 2023 us=456754 management_client_group = '[UNDEF]'
Sun Feb 26 15:31:13 2023 us=456762 management_flags = 0
Sun Feb 26 15:31:13 2023 us=456768 shared_secret_file = '[UNDEF]'
Sun Feb 26 15:31:13 2023 us=456775 key_direction = not set
Sun Feb 26 15:31:13 2023 us=456783 ciphername = 'AES-256-CBC'
Sun Feb 26 15:31:13 2023 us=456790 ncp_enabled = DISABLED
Sun Feb 26 15:31:13 2023 us=456796 ncp_ciphers = 'AES-256-GCM:AES-128-GCM'
Sun Feb 26 15:31:13 2023 us=456804 authname = 'SHA256'
Sun Feb 26 15:31:13 2023 us=456814 prng_hash = 'SHA1'
Sun Feb 26 15:31:13 2023 us=456821 prng_nonce_secret_len = 16
Sun Feb 26 15:31:13 2023 us=456827 keysize = 0
Sun Feb 26 15:31:13 2023 us=456834 engine = DISABLED
Sun Feb 26 15:31:13 2023 us=456840 replay = ENABLED
Sun Feb 26 15:31:13 2023 us=456847 mute_replay_warnings = DISABLED
Sun Feb 26 15:31:13 2023 us=456863 replay_window = 64
Sun Feb 26 15:31:13 2023 us=456887 replay_time = 15
Sun Feb 26 15:31:13 2023 us=456901 packet_id_file = '[UNDEF]'
Sun Feb 26 15:31:13 2023 us=456908 use_iv = ENABLED
Sun Feb 26 15:31:13 2023 us=456916 test_crypto = DISABLED
Sun Feb 26 15:31:13 2023 us=456923 tls_server = DISABLED
Sun Feb 26 15:31:13 2023 us=456931 tls_client = ENABLED
Sun Feb 26 15:31:13 2023 us=456938 key_method = 2
Sun Feb 26 15:31:13 2023 us=456945 ca_file = 'ca.crt'
Sun Feb 26 15:31:13 2023 us=456952 ca_path = '[UNDEF]'
Sun Feb 26 15:31:13 2023 us=456959 dh_file = '[UNDEF]'
Sun Feb 26 15:31:13 2023 us=456965 cert_file = 'client.crt'
Sun Feb 26 15:31:13 2023 us=456974 extra_certs_file = '[UNDEF]'
Sun Feb 26 15:31:13 2023 us=456981 priv_key_file = 'client.key'
Sun Feb 26 15:31:13 2023 us=456988 pkcs12_file = '[UNDEF]'
Sun Feb 26 15:31:13 2023 us=456995 cipher_list = '[UNDEF]'
Sun Feb 26 15:31:13 2023 us=457002 cipher_list_tls13 = '[UNDEF]'
Sun Feb 26 15:31:13 2023 us=457019 tls_cert_profile = '[UNDEF]'
Sun Feb 26 15:31:13 2023 us=457026 tls_verify = '[UNDEF]'
Sun Feb 26 15:31:13 2023 us=457033 tls_export_cert = '[UNDEF]'
Sun Feb 26 15:31:13 2023 us=457039 verify_x509_type = 0
Sun Feb 26 15:31:13 2023 us=457047 verify_x509_name = '[UNDEF]'
Sun Feb 26 15:31:13 2023 us=457061 crl_file = '[UNDEF]'
Sun Feb 26 15:31:13 2023 us=457068 ns_cert_type = 0
Sun Feb 26 15:31:13 2023 us=457076 remote_cert_ku[i] = 65535
Sun Feb 26 15:31:13 2023 us=457083 remote_cert_ku[i] = 0
Sun Feb 26 15:31:13 2023 us=457089 remote_cert_ku[i] = 0
Sun Feb 26 15:31:13 2023 us=457096 remote_cert_ku[i] = 0
Sun Feb 26 15:31:13 2023 us=457102 remote_cert_ku[i] = 0
Sun Feb 26 15:31:13 2023 us=457109 remote_cert_ku[i] = 0
Sun Feb 26 15:31:13 2023 us=457124 remote_cert_ku[i] = 0
Sun Feb 26 15:31:13 2023 us=457131 remote_cert_ku[i] = 0
Sun Feb 26 15:31:13 2023 us=457138 remote_cert_ku[i] = 0
Sun Feb 26 15:31:13 2023 us=457145 remote_cert_ku[i] = 0
Sun Feb 26 15:31:13 2023 us=457161 remote_cert_ku[i] = 0
Sun Feb 26 15:31:13 2023 us=457168 remote_cert_ku[i] = 0
Sun Feb 26 15:31:13 2023 us=457175 remote_cert_ku[i] = 0
Sun Feb 26 15:31:13 2023 us=457181 remote_cert_ku[i] = 0
Sun Feb 26 15:31:13 2023 us=457188 remote_cert_ku[i] = 0
Sun Feb 26 15:31:13 2023 us=457195 remote_cert_ku[i] = 0
Sun Feb 26 15:31:13 2023 us=457202 remote_cert_eku = 'TLS Web Server Authentication'
Sun Feb 26 15:31:13 2023 us=457209 ssl_flags = 0
Sun Feb 26 15:31:13 2023 us=457226 tls_timeout = 2
Sun Feb 26 15:31:13 2023 us=457233 renegotiate_bytes = -1
Sun Feb 26 15:31:13 2023 us=457241 renegotiate_packets = 0
Sun Feb 26 15:31:13 2023 us=457249 renegotiate_seconds = 3600
Sun Feb 26 15:31:13 2023 us=457257 handshake_window = 60
Sun Feb 26 15:31:13 2023 us=457263 transition_window = 3600
Sun Feb 26 15:31:13 2023 us=457270 single_session = DISABLED
Sun Feb 26 15:31:13 2023 us=457277 push_peer_info = DISABLED
Sun Feb 26 15:31:13 2023 us=457284 tls_exit = DISABLED
Sun Feb 26 15:31:13 2023 us=457303 tls_auth_file = '[UNDEF]'
Sun Feb 26 15:31:13 2023 us=457310 tls_crypt_file = '[UNDEF]'
Sun Feb 26 15:31:13 2023 us=457334 server_network = 0.0.0.0
Sun Feb 26 15:31:13 2023 us=457348 server_netmask = 0.0.0.0
Sun Feb 26 15:31:13 2023 us=457359 server_network_ipv6 = ::
Sun Feb 26 15:31:13 2023 us=457367 server_netbits_ipv6 = 0
Sun Feb 26 15:31:13 2023 us=457386 server_bridge_ip = 0.0.0.0
Sun Feb 26 15:31:13 2023 us=457395 server_bridge_netmask = 0.0.0.0
Sun Feb 26 15:31:13 2023 us=457404 server_bridge_pool_start = 0.0.0.0
Sun Feb 26 15:31:13 2023 us=457421 server_bridge_pool_end = 0.0.0.0
Sun Feb 26 15:31:13 2023 us=457429 ifconfig_pool_defined = DISABLED
Sun Feb 26 15:31:13 2023 us=457437 ifconfig_pool_start = 0.0.0.0
Sun Feb 26 15:31:13 2023 us=457453 ifconfig_pool_end = 0.0.0.0
Sun Feb 26 15:31:13 2023 us=457461 ifconfig_pool_netmask = 0.0.0.0
Sun Feb 26 15:31:13 2023 us=457469 ifconfig_pool_persist_filename = '[UNDEF]'
Sun Feb 26 15:31:13 2023 us=457476 ifconfig_pool_persist_refresh_freq = 600
Sun Feb 26 15:31:13 2023 us=457483 ifconfig_ipv6_pool_defined = DISABLED
Sun Feb 26 15:31:13 2023 us=457493 ifconfig_ipv6_pool_base = ::
Sun Feb 26 15:31:13 2023 us=457509 ifconfig_ipv6_pool_netbits = 0
Sun Feb 26 15:31:13 2023 us=457517 n_bcast_buf = 256
Sun Feb 26 15:31:13 2023 us=457524 tcp_queue_limit = 64
Sun Feb 26 15:31:13 2023 us=457531 real_hash_size = 256
Sun Feb 26 15:31:13 2023 us=457538 virtual_hash_size = 256
Sun Feb 26 15:31:13 2023 us=457545 client_connect_script = '[UNDEF]'
Sun Feb 26 15:31:13 2023 us=457552 learn_address_script = '[UNDEF]'
Sun Feb 26 15:31:13 2023 us=457559 client_disconnect_script = '[UNDEF]'
Sun Feb 26 15:31:13 2023 us=457566 client_config_dir = '[UNDEF]'
Sun Feb 26 15:31:13 2023 us=457572 ccd_exclusive = DISABLED
Sun Feb 26 15:31:13 2023 us=457589 tmp_dir = '/tmp'
Sun Feb 26 15:31:13 2023 us=457597 push_ifconfig_defined = DISABLED
Sun Feb 26 15:31:13 2023 us=457606 push_ifconfig_local = 0.0.0.0
Sun Feb 26 15:31:13 2023 us=457615 push_ifconfig_remote_netmask = 0.0.0.0
Sun Feb 26 15:31:13 2023 us=457630 push_ifconfig_ipv6_defined = DISABLED
Sun Feb 26 15:31:13 2023 us=457641 push_ifconfig_ipv6_local = ::/0
Sun Feb 26 15:31:13 2023 us=457650 push_ifconfig_ipv6_remote = ::
Sun Feb 26 15:31:13 2023 us=457665 enable_c2c = DISABLED
Sun Feb 26 15:31:13 2023 us=457672 duplicate_cn = DISABLED
Sun Feb 26 15:31:13 2023 us=457678 cf_max = 0
Sun Feb 26 15:31:13 2023 us=457685 cf_per = 0
Sun Feb 26 15:31:13 2023 us=457692 max_clients = 1024
Sun Feb 26 15:31:13 2023 us=457699 max_routes_per_client = 256
Sun Feb 26 15:31:13 2023 us=457708 auth_user_pass_verify_script = '[UNDEF]'
Sun Feb 26 15:31:13 2023 us=457716 auth_user_pass_verify_script_via_file = DISABLED
Sun Feb 26 15:31:13 2023 us=457723 auth_token_generate = DISABLED
Sun Feb 26 15:31:13 2023 us=457732 auth_token_lifetime = 0
Sun Feb 26 15:31:13 2023 us=457739 port_share_host = '[UNDEF]'
Sun Feb 26 15:31:13 2023 us=457745 port_share_port = '[UNDEF]'
Sun Feb 26 15:31:13 2023 us=457753 client = ENABLED
Sun Feb 26 15:31:13 2023 us=457759 pull = ENABLED
Sun Feb 26 15:31:13 2023 us=457767 auth_user_pass_file = '/vpn/vpn.auth'
Sun Feb 26 15:31:13 2023 us=457777 OpenVPN 2.4.9 x86_64-alpine-linux-musl [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD] built on Apr 20 2020
Sun Feb 26 15:31:13 2023 us=457842 library versions: OpenSSL 1.1.1g 21 Apr 2020, LZO 2.10
Sun Feb 26 15:31:13 2023 us=458020 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Sun Feb 26 15:31:13 2023 us=464819 Control Channel MTU parms [ L:1621 D:1212 EF:38 EB:0 ET:0 EL:3 ]
Sun Feb 26 15:31:18 2023 us=470636 RESOLVE: Cannot resolve host address: 87-1-fr.cg-dialup.net:443 (Try again)
Sun Feb 26 15:31:18 2023 us=470712 Data Channel MTU parms [ L:1621 D:1450 EF:121 EB:406 ET:0 EL:3 ]
Sun Feb 26 15:31:18 2023 us=470927 Local Options String (VER=V4): 'V4,dev-type tun,link-mtu 1569,tun-mtu 1500,proto UDPv4,cipher AES-256-CBC,auth SHA256,keysize 256,key-method 2,tls-client'
Sun Feb 26 15:31:18 2023 us=470959 Expected Remote Options String (VER=V4): 'V4,dev-type tun,link-mtu 1569,tun-mtu 1500,proto UDPv4,cipher AES-256-CBC,auth SHA256,keysize 256,key-method 2,tls-server'
Sun Feb 26 15:31:23 2023 us=474574 RESOLVE: Cannot resolve host address: 87-1-fr.cg-dialup.net:443 (Try again)
Sun Feb 26 15:31:23 2023 us=474636 Could not determine IPv4/IPv6 protocol
Sun Feb 26 15:31:23 2023 us=474948 SIGUSR1[soft,init_instance] received, process restarting
Sun Feb 26 15:31:23 2023 us=474995 Restart pause, 5 second(s)
Sun Feb 26 15:31:28 2023 us=475364 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Sun Feb 26 15:31:28 2023 us=475450 Re-using SSL/TLS context
Sun Feb 26 15:31:28 2023 us=475710 Control Channel MTU parms [ L:1621 D:1212 EF:38 EB:0 ET:0 EL:3 ]
Sun Feb 26 15:31:33 2023 us=482270 RESOLVE: Cannot resolve host address: 87-1-fr.cg-dialup.net:443 (Try again)
Sun Feb 26 15:31:33 2023 us=482352 Data Channel MTU parms [ L:1621 D:1450 EF:121 EB:406 ET:0 EL:3 ]
Sun Feb 26 15:31:33 2023 us=482531 Local Options String (VER=V4): 'V4,dev-type tun,link-mtu 1569,tun-mtu 1500,proto UDPv4,cipher AES-256-CBC,auth SHA256,keysize 256,key-method 2,tls-client'
Sun Feb 26 15:31:33 2023 us=482589 Expected Remote Options String (VER=V4): 'V4,dev-type tun,link-mtu 1569,tun-mtu 1500,proto UDPv4,cipher AES-256-CBC,auth SHA256,keysize 256,key-method 2,tls-server'
Salut,modifié dans le YML la ligne suivante :
oui, un probleme de passelle multiple sur DSMSalut, je ne sais pas comment t'aider DSM, c'est juste sur syno?
Tu aurai monté un dossier /etc/ hors du conteneur ? Bizarre il semble parler de fichier manquantUne idée?![]()
merci pour ton retour, j'ai passé la journée à chercher toutes les erreurs que j'avais, à 18H ca m'a saouléSalut,
Pas besoin de modifier cette ligne.
Aussi pour avoir essayé TrueNas, si tu créer des conteneur en dehors de leurs interface, alors les conteneurs n'ont pas acces a internet, il faut modifier une fichier de la config de docker pour cela, fichier qui est recharger en cas de redémarrage de la machine. C'est une des raisons qui m'a fait quitter TrueNAS. OMV est bien plus adapté a ce genre de chose.
Pour ce qui est du fichier a modifier, je ne suis plus sur, c'était dans /etc/docker/daemon.json me semble.
Si tu recherche "truenas docker not access internet" tu devrais trouver pas mal d'info sur le sujet.
docker compose down
docker system prune
Hello, voilà le message que j'ai
"docker-compose up -d
WARN[0000] network vpn-network: network.external.name is deprecated. Please set network.name with external: true
[+] Running 1/9
⠿ Container vpn Started 0.8s
⠿ Container sonarr Starting 1.0s
⠿ Container radarr Starting 1.0s
⠿ Container prowlarr Starting 1.0s
⠿ Container qbittorrent Starting 1.0s
⠿ Container lidarr Starting 1.0s
⠿ Container jackett Starting 1.0s
⠿ Container flaresolverr Starting 1.0s
⠿ Container rutorrent Starting 1.0s
Error response from daemon: failed to create shim task: OCI runtime create failed: runc create failed: unable to start container process: can't get final child's PID from pipe: EOF: unknown"
Rien de marche du premier coup chez moi...
ici le log du conteneur vpn:
Dump terminated
+ exec sg vpn -c 'openvpn --cd /vpn --config /vpn/deluge.ovpn --script-security 2 --redirect-gateway def1 --route-up '\''/bin/sh -c " iptables -A OUTPUT -d 127.0.0.11 -j ACCEPT"'\'' --route-pre-down '\''/bin/sh -c " iptables -D OUTPUT -d 127.0.0.11 -j ACCEPT"'\'' --auth-user-pass /vpn/vpn.auth '
Options error: --up script fails with '/etc/openvpn/update-resolv-conf': No such file or directory (errno=2)
Options error: Please correct this error.
Use --help for more information."
# find /volume0 -type d -name modules | grep lib 2>/dev/null
/volume0/usr/builtin/lib/modules
C'est pour créer en quelques sorte un espace bridge pour les connexions.Sur OMV6, l’étape de Tun.sh est obligatoire ? Ça consiste en quoi exactement ?
