docker run --cap-add=NET_ADMIN --device=/dev/net/tun -d \
-v /volume1/Container:/data \
-v /etc/localtime:/etc/localtime:ro \
-e "OPENVPN_PROVIDER=PIA" \
-e "OPENVPN_USERNAME=monUserPIA" \
-e "OPENVPN_PASSWORD=monMdpPIA" \
-e LOCAL_NETWORK=192.168.1.0/100 \
--log-driver json-file \
--log-opt max-size=10m \
-p 9091:9091 \
haugene/transmission-openvpn
Fri Nov 24 21:32:21 2017 library versions: OpenSSL 1.0.2g 1 Mar 2016, LZO 2.08
Fri Nov 24 21:32:21 2017 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Fri Nov 24 21:32:21 2017 TCP/UDP: Preserving recently used remote address: [AF_INET]109.201.154.192:1198
Fri Nov 24 21:32:21 2017 UDP link local: (not bound)
Fri Nov 24 21:32:21 2017 UDP link remote: [AF_INET]109.201.154.192:1198
Fri Nov 24 21:32:21 2017 WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this
Fri Nov 24 21:32:21 2017 [14162b986ea31b50fccaa9bd5e3c8e87] Peer Connection Initiated with [AF_INET]109.201.154.192:1198
Fri Nov 24 21:32:22 2017 TUN/TAP device tun0 opened
Fri Nov 24 21:32:22 2017 do_ifconfig, tt->did_ifconfig_ipv6_setup=0
Fri Nov 24 21:32:22 2017 /sbin/ip link set dev tun0 up mtu 1500
Fri Nov 24 21:32:22 2017 /sbin/ip addr add dev tun0 local 10.59.10.6 peer 10.59.10.5
Fri Nov 24 21:32:22 2017 /etc/transmission/start.sh tun0 1500 1558 10.59.10.6 10.59.10.5 init
Updating TRANSMISSION_BIND_ADDRESS_IPV4 to the ip of tun0 : 10.59.10.6
Generating transmission settings.json from env variables
Transmission will run as
User name: root
User uid: 0
User gid: 0
STARTING TRANSMISSION
CONFIGURING PORT FORWARDING
Transmission startup script complete.
Fri Nov 24 21:32:22 2017 Initialization Sequence Completed
Port forwarding is already activated on this connection, has expired, or you are not connected to a PIA region that supports port forwarding
curl encountered an error looking up new port: 56
docker run --privileged -d \
-v /share/Multimedia/:/data \
-v /share/Multimedia/:/data/completed \
-e OPENVPN_PROVIDER=NORDVPN \
-e OPENVPN_CONFIG=France \
-e OPENVPN_USERNAME='login' \
-e OPENVPN_PASSWORD='mdp' \
-e "TRANSMISSION_PORT_FORWARDING_ENABLED=true" \
-e "TRANSMISSION_RPC_AUTHENTICATION_REQUIRED=true" \
-e "TRANSMISSION_RPC_ENABLED=true" \
-e "TRANSMISSION_RPC_USERNAME=qnap" \
-e "TRANSMISSION_RPC_PASSWORD=qnap" \
-e "TRANSMISSION_BLOCKLIST_ENABLED=true" \
-e "TRANSMISSION_BLOCKLIST_URL=http://list.iblocklist.com/?list=fr&fileformat=p2p&archiveformat=gz" \
-e "OPENVPN_OPTS=--inactive 3600 --ping 10 --ping-exit 60" \
-e "LOCAL_NETWORK=192.168.xxx.xxx/24" \
-p 49092:49092 \
--dns 50.116.40.226 \
--dns 104.238.153.178 \
--restart=always \
--name Transmission-NordVPN \
valerimarcel a dit:Bonjour
Je ne dois pas être bien reveillé mais le tuto il est ou, j'ai bien le début mais...
Merci de votre aide
