QNAP [ TransmissionBT v3 ] [ 3.0.0.3 ] Transmission is a fast, easy, and free BitTorrent client.
Trinida a dit:
Salut et merci pour ton expertise sur Transmission,
y' t'il la place sur le serveur dorénavant pour le package en ARM-X19? Mon vieux TS-412 et moi sommes impatients. :D
Bye!
le portage est un peu compliqué... les sources ont du mal a compilé avec la vieille libc des ARMv5
toutes autres sont dispo
x31, x86 (en attente de place sur le repo)
arm64, x41 et x86_64 ... aprés ca dépend de ton NAS
armv5 c'est du x19
très compliqué de nos jours à compiler pour cette archi, les source ne sont plus adaptés...
j'ai même demandé plusieurs fois de patch à un dev, il s'est foutu de ma gueule en croyant c'était un Palm Pilot :lol:
QoolBox a dit:
armv5 c'est du x19
C'est un Qnap TS-412 sous QTS 4.3.3.
LibertyX82 a dit:
Hi,
there is an Problem by using SSL Trackers etc. i think it is caused on the reason that transmission is verifying SSL certificates since version 3.0
see
https://github.com/transmission/transmission/pull/334
https://github.com/openwrt/packages/issues/5665
For that check there is an ca bundle file needed that mused be stored in /etc/ssl/certs/ca-certificates.crt
I am having the same problem.
https trackers are no connecting, I get the error: "Could not connect to tracker"
http and udp are working fine.
Exactly!
I was having the same problem with a few trackers (as mentioned earlier), so I was forced to downgrade to 2.94 again.
did you installed :
CACert + Qperl
or
Qapache
or
Apache74
or
Apache73
all of them are generating and updating those missing certificates
dont think, it most a reverse proxy .... here the issue is link to ca-certificates.crt missing by default on Qnap
and need be generated by a perl script
I found some more info regarding https and SSL:
https://forum.transmissionbt.com/viewtopic.php?f=2&t=20406
Transmission is using cURL library to make HTTP requests to trackers. As long as that library is built with SSL support (and potentially against an SSL library that supports a particular SSL/TLS version in use by the tracker), Transmission itself supports SSL.
J’ai actuellement transmission sur un TS231P je voulais savoir comment migrer vers la nouvelle version.
Logiciel à installer et comment recuperer mes fichiers en seed
Merci par avance
junantho a dit:
Merci par avance
J'ai fait ça aujourd'hui. J'avais QTransmission v2. 93. Je suis passé à transmission v3
Les 2 instances étant lancé, j'ai copier coller les dossiers resume et torrent qui se trouvent à /opt/Transmission/etc/ vers opt/QTransmission3/etc/
J'ai arrêté les 2 instances et relancé Transmission v3
Pour ce qui est du fichier settings.json, j'ai préféré le modifier selon mes besoins plutôt que faire un copier coller.
salut
merci pour les informations j'ai réussi aujourd’hui je vais voir si ça fonctionne pendant une semaine.
par contre impossible de l'installer via l'installation de QPKG local(version incompatible) obligé d'utiliser le repo QNAPCLUB
Comme certains au dessus, j'ai dû revenir sur la version 2.94.
La connexion ne se fait pas avec certains trackers (ceux basés sur UNITED il me semble chez moi).
Quelqu'un a une solution pour résoudre ce problème ?
je pense c'est lié a CURL ... faut que je recompile qu'il aille chercher les bon certificat SSL au bon endroit
après je pense que QBitorrent est 100 fois mieux
Salut, J'ai depuis peu un problème de certificat dépassé.
Comment résoudre ce problème ?
Merci par d'avance.
