QNAP [ QSABnzbdPlus ] [ 3.5.3 ] Usenet Downloader
Hi,
can it be that the par2 repair does not work in the 64bit QSABNZBD?
As soon as a corrupted file tries to repair an error accurs saying "Repair failed, not enough repair blocks (XXX short)".
And the blocks short is the entire file.
So currently no corrupted downloads will be finished correctly.
best regards
Lenny
LennyM a dit:
Hi,
best regards
Lenny
think it is in the known issue : https://github.com/sabnzbd/sabnzbd/blob/develop/ISSUES.txt
***          Known issues               ***
- To prevent unexpectedly large NZBs from eating your download quota you can set
  the option 'size_limit' on the Config->Special page.
  Any NZB larger than this size will be set to paused and get a low priority.
- When par2 or unrar hang up, never just stop SABnzbd.
  Instead use your operating system's task manager to stop the par2 or unrar program.
  Forcing SABnzbd to quit may damage your queues.
  Windows-only:
  If you keep having trouble with par2 multicore you can disable it
  in Config->Switches.
  This will force the use of the old and tried, but slower par2cmdline program.
- A bug in Windows 7 may cause severe memory leaks when you use SABnzbd in
  combination with some virus scanners and firewalls.
  Install this hotfix:
  Description: http://support.microsoft.com/kb/979223/en-us
  Download location: http://support.microsoft.com/hotfix/KBHotfix.aspx?kbnum=979223&kbln=en-us
- Some Usenet servers have intermittent login (or other) problems.
  For these the server blocking method is not very favourable.
  There is an INI-only option that will limit blocks to 1 minute.
      no_penalties = 1
  See: https://sabnzbd.org/wiki/configuration/1.2/special
- Some third-party utilties try to probe SABnzbd API in such a way that you will
  often see warnings about unauthenticated access.
  If you are sure these probes are harmless, you can suppress the warnings by
  setting the option "api_warnings" to 0.
- On OSX you may encounter downloaded files with foreign characters.
  The par2 repair may fail when the files were created on a Windows system.
  The problem is caused by the PAR2 utility and we cannot fix this now.
  This does not apply to files inside RAR files.
- On Linux when you download files they may have the wrong character encoding.
  You will see this only when downloaded files contain accented characters.
  You need to fix it yourself by running the convmv utility (available for most Linux platforms).
  Possible the file system override setting 'fsys_type' might be solve things:
- The "Watched Folder" sometimes fails to delete the NZB files it has
  processed. This happens when other software still accesses these files.
  Some third-party utilities supporting SABnzbd are known to do this.
  We cannot solve this problem, because the Operating System (read Windows)
  prevents the removal.
- Memory usage can sometimes have high peaks. This makes using SABnzbd on very low
  memory systems (e.g. a NAS device or a router) a challenge.
- SABnzbd is not compatible with some software firewall versions.
  The Microsoft Windows Firewall works fine, but remember to tell this
  firewall that SABnzbd is allowed to talk to other computers.
- When SABnzbd cannot send notification emails, check your virus scanner,
  firewall or security suite. It may be blocking outgoing email.
- When you are using external drives or network shares on OSX or Linux
  make sure that the drives are mounted.
  The operating system will simply redirect your files to alternative locations.
  You may have trouble finding the files when mounting the drive later.
  On OSX, SABnzbd will not create new folders in /Volumes.
  The result will be a failed job that can be retried once the volume has been mounted.
- If you use a mounted drive as "temporary download folder", it must be present when SABnzbd
  starts up. If not, SABnzbd will use the default location.
  You can make SABnzbd wait for a mount of the "temporary download folder" by setting
  Config->Special->wait_for_dfolder to 1.
  SABnzbd will appear to hang until the drive is mounted.
- On some operating systems it looks like there is a problem with one of the standard Python libraries.
  It is possible that you get errors about saving admin files and even unexplained crashes.
  If so, you can enable the option for the alternative library.
  It has the same functionality, but is slower.
  We've had reports about this issue on non-mainstream Linux platforms.
  - OpenElec
  - Squeeze Linux
  There is a "special" option that will allow you to select an alternative library.
      use_pickle = 1
also read elsewhere about this problem... but cant find back the link
QoolBox a dit:
LennyM a dit:
Hi,
best regards
Lenny
  Windows-only:
      no_penalties = 1
  - OpenElec
  - Squeeze Linux
      use_pickle = 1
hm ok.
Don't find any par2 instances which weren't shut down correctly.
And the option to deactivate multicore par2 is not available on QSabnzbd 1.2 or is it?!
best regards
Lenny
Je crois j'ai le même problème.
Est ce que vous avez déjä trouver une solution pour ce problème ?
LE QpKG PAR2 , est ce qu'il faut être installé ou pas ?
Il est installé en ce moment
Merci pour la réponse rapide
Donc si j'ai bien compris , Installation du QPKG n'est pas nécessaire .
Je viens d'installer la nouvelle version 1.2 , Est ce que c'est normal que celle-ci ne se trouve pas dans le store qnapclub.eu
Je suis en 4.3 .
Bizarre
Je l'ai installé manuellement :-) Et j'ai mis le storeid dedans ...
mmmmm je pense parcequ'il na pas lextension x86 mais x86_64
je peux pas mettre en x86 tant qu'il y a la 4.2.2 ca risque de tout mettre en vrac
Hi QoolBox!
Thank you for this package. I'm working through the par2 issue with Safihre (core SABnzbd dev).
It looks like it could be a compat issue with the specific version of par2cmdline but we're still working through it.
Update: Safihre has patched the issue! It will be patched for 1.2.1. Though you can always manually apply the patch.
QoolBox do you plan on making QSABnzbdPlus auto-updatable like the other SABnzbd qpkg?
For the SSL issues. I found it easier to simply remove python references from Entware-ng and QCouchPotato packages and symlink them to the QSABnzbdPlus one since that one has zlib support compiled in. This lets QSABnzbdPlus also have access to the installed `pip` packages too. Working SSL certificate verification shakes out of the sickbeard_mp4_automator cryptography prerequesites as a bonus.
I've created a gist of my steps so far.
I'll keep it updated when the par2 issues is resolved too.
nzbjamz a dit:
Hi QoolBox!
Hi,
thanks.
I assume the fix is to apply/enter the -B parameter (Config>Switches>Post Processing>Extra PAR2 Parameters) within Sabnzbd and the par2 command?
I now use parameters -B -N
best regards
Lenny
LennyM a dit:
Yep :D ! Assuming you can specify the `parfolder` path too (I'm not sure if that's a static path or not).
