QNAP [ NetData ] [ 1.20.0 ] Real-time performance monitoring, done right
Même en essayant le téléchargement manuel depuis le site, le lien initial reste le même (https://qnapclub.eu/en/qpkg/model/download/462108/NetData_1.9.0_x86_64.qpkg) et j'aboutis à l'URL https://cdn.qnapclub.eu/qpkg_artifacts/NetData_1.9.0_x86_64/NetData_1.9.0_x86_64.qpkg, qui ne pointe sur rien.
J'arrive à télécharger la version précédente cela dit.
Fabien
QoolBox a dit:
hi,
i get following error after update
Access to file is not permitted: /opt/NetData/share/netdata/web//index.html
there seems to be a "/" too much
best regards
Leny
QoolBox a dit:
shouldnt be the problem
it runs fine on my TBS-453-DX with a clean install
strange.
I did a clean reinstall and still doesn't work (TS-680 pro). On my small 2Bay QNAP it runs as well...
I will look at it a little closer in the comign days.
Best regards
Lenny
below the reason and solution for the problem described before by me from the qnap forum.
You have to edit the netdata.conf via ssh with the following code.
Best regards
Lenny
LennyM a dit:
robtihanyi a dit:
FYI, this build for 1.13 contains an empty netdata.conf file, meaning it will error with insufficient permissions, on trying to load the webpage at port 9119.
This file can be found at /opt/NetData/etc/netdata/netdata.conf
The file needs to have the following contents for the build to work:
# NetData Configuration
# The current full configuration can be retrieved from the running
# server at the URL
#   http://localhost:19999/netdata.conf
# for example:
#   wget -O /etc/netdata/netdata.conf http://localhost:19999/netdata.conf
[global]
	run as user = netdata
	web files owner = root
	web files group = netdata
thnx,
finally I got it working again.
Best regards
Lenny
