Nouvelle salve de MAJ pour DSM sur nos NAS, avec la version 7.1.1-42962 Update 5 : https://www.synology.com/fr-fr/releaseNote/DSM#7_1
Version en anglais :
Version traduite en français :
Compte tenu des failles touchant OpenSSL, je n'ai pas attendu que le NAS daigne bien vouloir me la proposer, je l'ai fait manuellement.
Pour le moment rien à signaler.
Version: 7.1.1-42962 Update 5
(2023-04-12)
Important notes
- Your Synology NAS may not notify you of this DSM update because of the following reasons. If you want to update your DSM to this version now, please click here to update it manually.
- Your DSM is working fine without having to update. The system evaluates service statuses and system settings to determine whether it needs to update to this version.
- Depending on your Synology NAS model, this update will restart the device.
- Users of HD6500 can now create a Btrfs volume of up to 1 PB. This update automatically converts existing volumes that use the Btrfs (Peta Volume) file system to Btrfs. However, to create a volume larger than 200 TB, a RAID 6 storage pool and at least 64 GB of system memory are still required.
What’s New
- Updated OpenSSL to version 1.1.1t to fix multiple security vulnerabilities (CVE-2023-0286, CVE-2023-0215, CVE-2022-4450, CVE-2022-4304).
Fixed Issues
Remarques :
- Fixed an issue where users couldn't access DSM via the Bonjour service.
- Fixed stability issue of QuickConnect connections.
- Fixed an issue where Synology mobile apps remained signed in after users ended all connections following a password change.
- Fixed an issue of space reclamation not running according to the set schedule.
- Fixed a display issue concerning the notification about incompatible network interface cards.
- This version is released in a staged rollout.
(2023-04-12)
Notes importantes
- Votre Synology NAS peut ne pas vous informer de cette mise à jour DSM pour les raisons suivantes. Si vous souhaitez mettre à jour votre DSM vers cette version maintenant, veuillez cliquer ici pour le mettre à jour manuellement.
- Votre DSM fonctionne correctement sans avoir à mettre à jour. Le système évalue les états de service et les paramètres système pour déterminer s’il doit effectuer une mise à jour vers cette version.
- Selon votre modèle de Synology NAS, cette mise à jour redémarrera l’appareil.
- Les utilisateurs de HD6500 peuvent désormais créer un volume Btrfs allant jusqu’à 1 Po. Cette mise à jour convertit automatiquement les volumes existants qui utilisent le système de fichiers Btrfs (Peta Volume) en Btrfs. Toutefois, pour créer un volume supérieur à 200 To, un pool de stockage RAID 6 et au moins 64 Go de mémoire système sont toujours nécessaires.
Quoi de neuf
- Mise à jour d’OpenSSL vers la version 1.1.1t pour corriger plusieurs vulnérabilités de sécurité (CVE-2023-0286, CVE-2023-0215, CVE-2022-4450, CVE-2022-4304).
Problèmes résolus
Remarques :
- Correction d’un problème où les utilisateurs ne pouvaient pas accéder à DSM via le service Bonjour.
- Correction du problème de stabilité des connexions QuickConnect.
- Correction d’un problème où les applications mobiles Synology restaient connectées après que les utilisateurs aient mis fin à toutes les connexions suite à un changement de mot de passe.
- Correction d’un problème de récupération d’espace qui ne fonctionnait pas selon le calendrier établi.
- Correction d’un problème d’affichage concernant la notification concernant les cartes d’interface réseau incompatibles.
- Cette version est publiée dans un déploiement par étapes.
