P4sh0u
Je rencontre quelques complications concernant mon serveur mail, le port 993 de l'IMAP SSL n'a pas l'air d'être visible par des services comme Outlook ou Thunderbird. J'arrive à recevoir des mails mais je pense que certains n'ont pas été reçu...
Je l'installe en docker sous OMV.
Voici ma config :
version: '3'
services:
iredmail:
container_name: iredmail
image: iredmail/mariadb:stable
hostname: mail.exemple.com
ports:
- "8080:80"
- "4443:443"
- "110:110"
- "995:995"
- "143:143"
- "993:993"
- "25:25"
- "465:465"
- "587:587"
- "4190:4190"
environment :
- HOSTNAME=mail.exemple.com
- FIRST_MAIL_DOMAIN=exemple.com
- FIRST_MAIL_DOMAIN_ADMIN_PASSWORD=***
- ROUNDCUBE_DES_KEY=***
volumes:
- /srv/dev-disk-by-uuid-111ebfb2-241a-43b2-aa8b-8ded8f04ab93/docker/iredmail/data/backup-mysql:/var/vmail/backup/mysql
- /srv/dev-disk-by-uuid-111ebfb2-241a-43b2-aa8b-8ded8f04ab93/docker/iredmail/data/mailboxes:/var/vmail/vmail1
- /srv/dev-disk-by-uuid-111ebfb2-241a-43b2-aa8b-8ded8f04ab93/docker/iredmail/data/mlmmj:/var/vmail/mlmmj
- /srv/dev-disk-by-uuid-111ebfb2-241a-43b2-aa8b-8ded8f04ab93/docker/iredmail/data/mlmmj-archive:/var/vmail/mlmmj-archive
- /srv/dev-disk-by-uuid-111ebfb2-241a-43b2-aa8b-8ded8f04ab93/docker/iredmail/data/imapsieve_copy:/var/vmail/imapsieve_copy
- /srv/dev-disk-by-uuid-111ebfb2-241a-43b2-aa8b-8ded8f04ab93/docker/iredmail/data/custom:/opt/iredmail/custom
- /srv/dev-disk-by-uuid-111ebfb2-241a-43b2-aa8b-8ded8f04ab93/docker/iredmail/data/ssl:/opt/iredmail/ssl
- /srv/dev-disk-by-uuid-111ebfb2-241a-43b2-aa8b-8ded8f04ab93/docker/iredmail/data/mysql:/var/lib/mysql
- /srv/dev-disk-by-uuid-111ebfb2-241a-43b2-aa8b-8ded8f04ab93/docker/iredmail/data/clamav:/var/lib/clamav
- /srv/dev-disk-by-uuid-111ebfb2-241a-43b2-aa8b-8ded8f04ab93/docker/iredmail/data/sa_rules:/var/lib/spamassassin
- /srv/dev-disk-by-uuid-111ebfb2-241a-43b2-aa8b-8ded8f04ab93/docker/iredmail/data/postfix_queue:/var/spool/postfix
restart: unless-stopped
J'ai bien récupéré le certificat SSL mail.exemple.com via Nginx et je m'en sert également pour arriver sur la page de roundcube.
Ai-je manqué une étape ? Merci d'avance
Voici ma config :
version: '3'
services:
iredmail:
ports:
- "8080:80"
- "4443:443"
- "110:110"
- "995:995"
- "143:143"
- "993:993"
- "25:25"
- "465:465"
- "587:587"
- "4190:4190"
environment :
volumes:
