QNAP [ TDarr V2 ] [ 2.0.19 ] Distributed Transcoding System
QoolBox
Représentant QNAP
2 Janvier 2014
10 741
185
173
51
www.qnap.com
Oui
Source : https://tdarr.io
Download : adm/Intel x64 , arm64 (qpkg autoupdate it self)
Apache81 https://www.myqnap.org/product/tdarr-v2/
Apache82 https://www.myqnap.org/product/tdarr-v2-apache82/
Dependencies :
Apache81 or Apache82 (mandatory)
MUSL if you use MHandbrake QPKG (optional)
if you use another version set path in config file according documentation : https://docs.tdarr.io/docs/welcome/what
this QPKG required NAS has an internet connection for first install and updater working
Tdarr is a popular conditional transcoding application for processing large (or small) media libraries. The application comes in the form of a click-to-run web-app, which you run on your own device and access through a web browser.
Tdarr uses two popular transcoding applications under the hood: FFmpeg and HandBrake (which itself is built on top of FFmpeg).
Installed Tdarr V2 (Apache81) using TdarrV2_2.0.18.1_x86_64.qpkg on my QNAP TVS-873e running QTS 5.0.1.2376.
Apache & PHP 8.1.x v24548110 installed.
Opening app results in " This site can’t be reached vrsnas02 refused to connect."
using PuTTY to start Tdarr_Server shows multiple GLIBC modules missing (Putty output attached)
How can this be resolved please?
seems like developer has upgraded the libc for his binaries... and the one on NAS is too old...
I need check to make it run under another ELF version
Réactions: emeljay42
