Applied multiple security updates to further enhance system security.
Fixed Issues
Fixed an issue where the network interface on certain TS-431XeU, TS-x31K, TS-431X3, and TS-x31P3 models would occasionally stop responding.
Fixed an issue where the QDA-UMP drive adapter sometimes could not be detected when installed in a certain drive bay.
Fixed an issue that caused the NAS to stop responding if users enabled SSD cache acceleration while VMware ESXi server was rebooting.
Fixed an issue where hard disks on the NAS would sometimes spin up when the NAS was powered off after users re-plugged the power cord.
Resolved an issue where Control Panel could not display any DNS information in Domain Controller settings after users removed domain administrators from administrator groups.
Fixed an issue that caused prolonged login times in an environment that had a large number of domain users and domain groups.
Fixed an issue that prevented users from creating an SED storage pool again after removing an SED storage pool and then restarting the NAS.
Fixed an issue in iSCSI & Fibre Channel where users occasionally could not successfully expand iSCSI LUNs.
Fixed a localization issue in Storage & Snapshots where the string "Snapshot Replica" remained in English even when the system language was set to Hungarian.
Resolved an issue where QuLog Center would miss a log message about firmware version inconsistency between the system and an installed drive.
Resolved an issue where the QXG-10G2T-107 network expansion card could not respond after users updated the firmware.
Fixed an issue where users sometimes could not connect to file-based iSCSI LUNs via VMware ESXi 5.5 server.
Fixed a connection issue that would occur if users restarted a destination NAS while running a Snapshot Replica job.
Fixed an issue that affected Thunderbolt performance when users accessed SMB shared folders via Thunderbolt.
Resolved an issue where users could not find the NAS in Windows File Explorer > Network after enabling WireGuard VPN Server in QVPN Service.
Fixed an issue where Domain Controller could not be enabled when there was a local account whose username was "administrator".
Resolved an issue that sometimes caused an abnormal volume status after users restored system settings in Control Panel.
Fixed an issue that prevented users from copying files from the QVRProRecording folder to other folders after users updated QTS to 5.0.0.2055.
Fixed an issue in Network & Virtual Switch where static routes would occasionally disappear when users established VPN connections and created sync jobs in HBS3.
Fixed an issue where users could not perform DNS queries with IPv6 for the local device.
Resolved an issue that caused incorrect access permissions for home folders.
Fixed an issue where Control Panel would display incorrect memory slot information on the TS-873AeU.
Fixed an issue where users could not enable two reverse proxy rules at the same time if both rules shared the same source port number.
Resolved an issue where users could not connect to the NAS via SFTP if their usernames contained the @ character.
Fixed an issue in File Station where users could not disable a share link after opening the Qsync folder.
Fixed an issue in File Station where files uploaded via a share link had incorrect file permission settings.
Fixed an issue that caused Control Panel to stop responding when an administrator created a storage quota for a local user group.
Fixed an issue where SNMP OIDs (object identifiers) did not include firmware names when displaying firmware versions.
Fixed an issue where unexpected log messages would appear in System Event Log if users ran IHM health check for disks in sleep mode.
Fixed an issue where certain NAS models could not remember new network settings when users made changes to network configuration on the NAS LCD panel.
Known Issues
QTS and QuTS hero with newer kernel versions do not support ATTO Fibre Channel adapters. If you have already installed an ATTO Fibre Channel adapter on your device, we do not recommend updating the firmware to QTS 5.0.0 or QuTS hero h5.0.0 for the time being.
Thunderbolt connection between the NAS and Mac sometimes cannot automatically resume after users restart the NAS.
Users cannot connect to the destination NAS of a Snapshot Replica job if their usernames contain a space.
