QNAP [ Aria 2 ] [ 1.35.0 ] a lightweight multi-protocol & multi-source, cross platform download utility
QoolBox
Représentant QNAP
2 Janvier 2014
10 624
179
158
51
www.qnap.com
Source : https://github.com/aria2/aria2
UI based on AriaNG ( https://github.com/mayswind/AriaNg )
Download x86 , x64 , arm7, arm64
https://www.qnapclub.eu/fr/qpkg/881
QPKG INTEGRATION
listen on RPC Websocket 6800 by default
tokens set in /opt/AriaII/aria2.conf ( 7iQzqgg6Soe5MqpWGaLODhAbNcFwkFEaQYCQhCAtDrIZ by default )
use websocket connection to connected WebUI to aria2c daemon
aria2c command line also added to NAS $PATH
About
aria2 is a utility for downloading files. The supported protocols are HTTP(S), FTP, SFTP, BitTorrent, and Metalink. aria2 can download a file from multiple sources/protocols and tries to utilize your maximum download bandwidth. It supports downloading a file from HTTP(S)/FTP/SFTP and BitTorrent at the same time, while the data downloaded from HTTP(S)/FTP/SFTP is uploaded to the BitTorrent swarm. Using Metalink's chunk checksums, aria2 automatically validates chunks of data while downloading a file like BitTorrent.
Features
Here is a list of features:
Command-line interface
Download files through HTTP(S)/FTP/SFTP/BitTorrent
Segmented downloading
Metalink version 4 (RFC 5854) support(HTTP/FTP/SFTP/BitTorrent)
Metalink version 3.0 support(HTTP/FTP/SFTP/BitTorrent)
Metalink/HTTP (RFC 6249) support
HTTP/1.1 implementation
HTTP Proxy support
HTTP BASIC authentication support
HTTP Proxy authentication support
Well-known environment variables for proxy: http_proxy, https_proxy, ftp_proxy, all_proxy and no_proxy
HTTP gzip, deflate content encoding support
Verify peer using given trusted CA certificate in HTTPS
Client certificate authentication in HTTPS
Chunked transfer encoding support
Load Cookies from file using the Firefox3 format, Chromium/Google Chrome and the Mozilla/Firefox (1.x/2.x)/Netscape format.
Save Cookies in the Mozilla/Firefox (1.x/2.x)/Netscape format.
Custom HTTP Header support
Persistent Connections support
FTP/SFTP through HTTP Proxy
Download/Upload speed throttling
BitTorrent extensions: Fast extension, DHT, PEX, MSE/PSE, Multi-Tracker, UDP tracker
BitTorrent WEB-Seeding. aria2 requests chunks more than piece size to reduce the request overhead. It also supports pipelined requests with piece size.
BitTorrent Local Peer Discovery
Rename/change the directory structure of BitTorrent downloads completely
JSON-RPC (over HTTP and WebSocket)/XML-RPC interface
Run as a daemon process
Selective download in multi-file torrent/Metalink
Chunk checksum validation in Metalink
Can disable segmented downloading in Metalink
Netrc support
Configuration file support
Download URIs found in a text file or stdin and the destination directory and output file name can be specified optionally
Parameterized URI support
IPv6 support with Happy Eyeballs
Disk cache to reduce disk activity
